Re: Error from Kmotioncnc
Go to the machine type tab menu in mastercam and select machine definition manager. At the top of the window there is a icon for control definition. Select that. On the left under control topics select arc. Under arc center type change the xy plane to unsigned incremental. Then check out of that screen and hit yes to save. Check out of the next screen and hit yes to save again. Then repost your code and see if that fixes your problem.
Ben
Thank you!
Have reposted the code and will try again. Fingers crossed.
/Lars
1 Attachment(s)
Sorry to say that it did not work... get another error now.
Attachment 274776
Attachment 274776
/Lars
Sorry it didn't work. I was having the same issue and that's how I fixed it. If you want to post a picture of a few of your screens I'll compare to mine and see if there are any obvious differences. The same screen where you adjusted the arc settings and also the tolerance screen in the same area.
Ben
Also what post processor are you selecting? I am using inch not metric but I'll try a similar metric post to yours and see what I can come up with.
Ben
I guess a better question then what post is what are you selecting for machine type?
Ben
I have to get back to you on that. Not at the shop now. I think i have picked some standard 4 axs mill vmc. Cannot remember the exact name. I will post some screenshot later today.
Thank you for your help!
Im a beginner on all this.
/Lars
For Mastercam, I use the default router post, and it works perfectly save for some stuff that I have to delete prior to running. The only time I have seen an error like that is when I have tried to run a program from the middle without starting from the beginning.
I did the math for the incremental IJ needed for KMotionCNC. The radius is way off. As absolute IJ the Gcode doesn't make sense either.
Code:
Start IJ Center End cent to end
-53.77 6.406 -47.364 -23.199 24.165
11.611 24.165 35.776 -6.149 -41.925
Radius beg Radius end
24.999681218 48.3906277083
You might look at the CAM data and determine what it is trying to do. What kind of arc should be generated? Where would be the center? What would the radius be? Then you could probably look at the GCode and see what was wrong. A GCode Arc is pretty simple. The last coordinate is the starting point of the arc. The IJ is where the arc center is relative to the starting point (so add IJ to startxy to get the center). The specified XY coordinate is the end.
HTH
Regards
2 Attachment(s)
Here is some screenshots from the settings pages you wanted.
Attachment 274854
Attachment 274856
The Machine type selected is MILL 4 - AXIS VMC MM and the Postprocessor is Generic Fanuc 4X Mill.
I have not changed any settings in here except those you mentioned, the Arc one.
Maybe its the wrong postprocessor?
/Lars
Ah I just noticed changing the sign of J in the GCode (from 24.165 to -24.165) makes the beginning and ending radii equal.
Is there an "incremental signed" option?
Regards
1 Attachment(s)
Hi!
Yes there is.
Attachment 274862
What does all this mean? If there even is a easy way to explain this :)
Well, Signed radius is an option, shown in the Pic
I changed Control file to DEFAULT.CONTROL and Post-processor to MPFAN.PST. Now the error has gone away when simulating in KmotionCNC. The machine is at work so I cannot test run it until tomorrow.....
Hopefully this works!!
ARC center type now states: Delta start to center, what ever that means :)
Hi Lars,
Yes I was just about to suggest "Delta start to center". It means exactly that :)
(it means that IJ specify how far to go in XY from the arc's starting XY point to get to the XY center of the arc)
Good chance if it works in simulation it will work on the machine. I'm not sure what other differences are between the two different "posts" so the other option is to go back to the other and make that one change.
Good Luck
Regards
Problem solved!
Using another postprocessor made the trick!
Thnak you all for givning me the advise!
/Lars
