1 Attachment(s)
X2 mini mill head dimensions
I am working on a new project and am thinking about using an X2 head that can be purchased from Little Machine Shop. What I need to know are the dimensions of the head. I have attached a picture of the dimensions I need which are as follows.
A - Width of head casting
B - Height of Head Casting
C - Depth of head casting
D - Distance from rear of casting to spindle centerline
EDIT - I would also like the distance the spindle nose protrudes below the bottom of the casting.
I don't need exact measurements. Just a tape measure accuracy is good enough for what I need right now.
Thanks in advance.
John B.
Re: X2 mini mill head dimensions
A - 3.47"
B - 4.35"
C - 5.27"
Thanks.
Would anyone have the other 2 dimensions?
E - distance the spindle nose protrudes below the bottom of the casting.
Thanks again.
John B.
This drawing might help.
Spindle Drawing
Dan
I was going to make a mill with a head like that too. I bought a mini lathe head off eBay. Since buying it, I have since been given a different headstock assembly. If you could use a MT3 spindle headstock I can make you a good deal on it.
1 Attachment(s)
Harbor Freight X2
Attachment 271400
Hoss
