Y origin
Rhinofile> 2015-01-10_1810 - OlaviJing's library
Simulation> 2015-01-10_1811 - OlaviJing's library
G-code> 2015-01-10_1816 - OlaviJing's library
Here is the Rhino image,, and simulation,,ja starting g-code.
How do I get the correct X, Y zero point, when this goes completely wrong.
When it turns to a-axis, then Y-position is in the wrong place
Simulation look correct.but cutting place is wrong,
Kai
2 Attachment(s)
Re: Y origin
This is wrong foto sorry.
How can i delete wrong picture?
I PUT CORRECT PICTURE HERE>>>>2015-01-11_1147 - OlaviJing's library
What is correct A-origin value in my case.>>>aorigin2015-01-11_1059 - OlaviJing's library
What do you put this value?
I have a Sherline machine-deck 40mm higher than the A-axis. Attachment 264002
Re: Y origin
That value in the simulator does not affect the posted code. It just moves the machine model so that the part can be represented in the machine more accurately.
