Re: manual oil pump problems
I had the same problem on mine some time ago and found out that your supposed to pull the pump about once a year (freq. depends on problems) and clean the filter in the bottom of the pump. It can and will get clogged up and you will experience the scenario you describe.
Oh Cool, thanks Art. That makes sense. I'll clean it up.
Joe
Mine (on a 770) was and is still is wonky from new. Sometimes with many quick strokes I can get the plunger to grab a bit of oil which gradually gets pushed up through the lines. I suspect it would be easier to fix by taking it apart and checking what is wrong rather than spending time grumbling about it, but sometimes I do things the hard way. The oil lines seem to leak and get air in them too. I need to find a couple of round toits.
I did it the easy way. I put an automatic oiler on my machine. Now, every 4 hours it gets a 12 second blast of oil.
Well I took it apart, cleaned the filter which was not dirty at all. Still no luck, same issue. I think its the o-ring in front of the piston, it looks like its a little small and I think its sucking air. I'll have to get some o-rings and size one up.
