pipe steel plasma cutting machine informaiton
4-6 axis CNC pipe plasma and flame cutting machine is special CNC equipment which is used for cutting metal pipe automatically.It can realize auto program and auto CNC nesting work for any complicated joint type of intertube and pipe and nonintertube and can cut any type welding bevel at one time.This product is widely used for steel structure,shipbuilding,bridge and heavy machine industries.Suitable fo rcutting cilinder branch , two or three -layer saddle cutting of the main pipe.It is suitable for large quantities of professional intersection pipe cutting.Cutting material: low carbon steel, stainless steel and non-ferrous metal, etc. machine can be designed according to the different needs of users.
Features
1.Charge on the cut in several different directions and different diameters of cylindrical holes intersecting line to meet the head of the axis of branch pipe axis and eccentricity of the eccentric and non-perpendicular conditions.
2.Branch ends in intersecting line cutting cylinder ends to meet the branch head of the axis of the eccentric axis and eccentricity of the vertical and non-intersecting,sloping intersection conditions.
3.Cut the pipe end can be inclined cutting face.
4.Can cut the pipe welded on the elbow,"shrimp festival" at both ends of oblique cut surface.
5.Intersects with the circular cutting head to the branch ends intersecting line.
6.Variable angle to cut the groove surface.
7.Can cut the pipe square hole on the waist-shaped hole.
Cutting function
1.Intersection cylindrical hole cutting of different directions and diameters on main pipe for vertical intersection between branch pipe and main pipe.
2.Intersection cylindrical end cutting on brand pipe for vertical intersection between branch pipe and main pipe.
3.Bevel cutting on Pipe end
4.Welding Elbow cutting on pipe
5.Branch pipe Intersection end cutting connected with ring main pipe
6.Square hole and branch hole cuting on pipe
7.Cutting off of pipes
https://www.youtube.com/watch?v=O37T...PS9nyVywMxYjmw
More information: please contact CNC Solution
[email protected]
