Hello everybody
I know that it’s possible to set the zero point over the parameter with older Fanuc controllers (#2501=#5021 set neutral point X axis)
Now I would need the parameters for the C axis of the above named controller ( 5 axis with A and C axis)
I would like to change the zero point of the C axis several times during a program run- as it would save a lot of programming time.
I hope I expressed myself in a comprehensible manner and I am quite curious to find out if somebody can help me put!
Kind regards
SV20 relative absolute
X #5021 X#5041
Z1 #5022 Z1#5042
A #5023 A#5043
Y #5024 Y#5044
B #5025 B#5045
Z2 C2 #5022 C2 #5042
E C2 #5023 C2 #5043
Revolver C2 #5025 C2 #5045
SR20 relative absolute
X #5021 X#5041
Z #5022 Z#5042
Y #5024 Y#5044
XB C2 #5021 C2 #5041
ZB C2 #5022 C2 #5042
I am not quite sure if that helps you out!
Hello
Thanks a lot for your help. Unfortunately I don’t know at all what that means =(
Maybe you could explain it to me??
Kind regards
Hello
I know setting/moving the zero point in the program with G10.
e.g. G10 L2 P1 X.. Y.. Z.. C..
or incremental G10 L2 P1 U.. V.. W.. H..
P1=G54, P2=G55 and so on..
So "G10 L2 P1 H90." turns the zero point of the C axis in G54 around +90 degrees.
Are you working on a milling machine? I don’t know that at all... I mainly program incremental anyway but if you don’t want to move it permanently and only in the middle of the program then it’s easier to do it with G50.
