No motor movement using mach3 and g540
I have a x2 mill I am converting to CNC. I cannot get any motor movement. I loaded the 540xml file from geckodrive for the g540. Checked configuration and found no errors. With I power up the driver the motors lock up and you cannot move them by hand. I can run a wizard and see it move on the screen but no movement on motors. On the g540 there is a green light and the trim adjustment holes have red LEDs on but I don't have a fault lights on. When I did install mach 3 it did install the printer driver. Is there a way to test the G540 by itself.
Thanks for any help I can get
Doug
x2 Harbor Freight Mill with CNC Fusion Kit 2
cncrouterparts 3-axis 23 nema Kit
Geckodrive g540 version 4
48 volt power supply
Mach 3
