4 Attachment(s)
stuck with "prof" 4 axis stepper driver tb6560 + LCD digital display + Pulse keyb.
Hi guys!
I've recently got the item in the title from Aliexpress (Professional 4 axis stepper motor driver tb6560 + LCD digital display + Pulse handle keyboard-in Motor Driver from Industry & Business on Aliexpress.com). Plus 3 NEMA17 steppers which I intend to use in a small test-application.
Though chinese items may to be not very trustworthy they are cheap. You now what I mean...
These looks OK. Attachment 201320 Attachment 201322 Except the documentation wich is imposible to be understood.
From the pictures it can be seen that the controller itself is the same reffered in some others threads which means is a "known" item between the gurus of CNC ZOne.
After a two days struggle with the controller's menu I've managed to make the steppers spin, from the controller's keyboard buttons. Which gave me hope.
So I moved further and I connected the controller to a MACH3 PC. I've made (after 2 times reading both MACH3 docs & 10 times the so-called chinese docs) the MACH 3 settings and start a test.
Suprisingly the controller's display began to run and after some tuning it become to give the MACH3 readings. So, what's the problem, you will ask. The problem is that the stepper don't rotate at all whatever the display readings are!
In my newbee opinion, it is something I miss with that crap controller's menu which I don't manage to fully understand because of the pile of sh.t named "manual". I suspect this chiefly because in a "learning mode" of the controller, I can move the stepper wrom the controller buttons (this I already told you) and, if simultaneosly I try to move it from MACH3 button (yes!!! I tryed even this!!) the steppers begin tu tramble and stuck...
So can anyone of you give some ideeas to un-stuck me? Or maybe you know how to find a decent manual for this controller or, even, can anyone understand better than me what is written in that damned manual?
I will be grateful to you to help me and I'm looking forward to it!
Alex
a new day, another situation
Hi again guys! It's me again!
A (partial) miracle has happened! In the morning I began to "dig" again my problem.
After connecting the power source I was surprised to find that the facts were changed, apparently without my intervention. Maybe it was God's one. :)
The last thing I've done yesterday it was disconnecting the display and buttons from the board. I intended to try just the drivers (without display and buttons) with MACH, hoping that it wil work this way. It didn't.
In the morning, after conecting the source and the paralel cable, i found that the situation was somehow reversed: the steppers were spinning (with MACH3 commands) but the controller's display doesn't follow the "MACH3 movements".
They were responding bad to the controller buttons (both motors for Y axis, only one for the X axis, and again the same, for the Z axis where no stepper is installed!) while the paralel cable is connected and well (like yesterday) when not.
The display follows the movements made only by controller's buttons.
Figuring it's about some MACH3 setting I started to probe until i've managed to get the correct MACH3 settings which I can give to anyone who care for them! :)
Still the display of the controller wont work beside the controller buttons' commands.
Of course I did my best (a lot o buttoning!) to deciphre the chinese menus hoping that there is a "clou" there but I didn't succeded. Pitty! :(
Nevertheless, this situation is much better than yesterday because now I can use the item to my tests.
Of course the fact I don't know what really happened give me thrills because the reverse phenomena can happen tomorow, and I wouldn't now how to get back. :(
That's why I am still hoping to get some explanations from one of this forum's gurus.
Re: stuck with "prof" 4 axis stepper driver tb6560 + LCD digital display + Pulse keyb
Hi
I have the HY-JK05-K6 Breakout board with display and the same button pad controller on a pendant. I am not using the 6560 driver board but other 6600 based controller modules.
I just got my controller cabinet wired up and motors spinning for the first time last night. I used the HY-JK05-K6 in manual mode and got my motors to spin using the jog buttons. After I received the HY-JK05-K6, I wrote it off as a loss due to the lack of real documentation. I decided to try it first in manual mode last night as getting LinuxCNC set up for the breakout board is a whole other project.
Have you been able to be productive with your setup and have you found any real documentation?
Otherwise I will continue to plan on using LinuxCNC and other breakout boards.
If Linux is a problem I will move up to Planet CNC which is a turnkey system with real tech support.
But for now using the HY-JK05-K6 as a simple jog device will be very useful while I fit the motors to the machines.
I would offer that the wiring should look neat and clean with meticulous striping so not to nick the wire. Signal wires should be separated by several inches and not parallel to the stepper wires or high current power wires to the drive modules. When the wiring looks like artwork, then you can easily see if something is broke or out of place.
I believe we make our own luck. I worked on the same Coast Guard aircraft that I would fly in.
