Help with NPN proximity sensor wiring in parallel
Ok i have my sensors mounted and they work if i only have 1 sensor. however as soon as i try to run them in parallel i can not get them to trip unless they are both tripped. Helllpppp I am abut to pull out my hair.
These are the sensors i am working with I am using 12 v power supply to power them Amazon.com: Amico DC 6-36V 300mA NPN NC 8mm Tubular Inductive Proximity Sensor Approach Switch LJ18A3-8-Z/AX: Home Improvement
I am using this as the BOB
http://www.kelinginc.net/KL-DB25.pdf
