Hi
I imported a IGS file but the part is composed with just surfaces and i wanted to know how i create thickness because when i create the toolpaths all the walls desappears.
Tks
Printable View
Hi
Tks
You can not make them thicker as they are surfaces now if you turn them into Sheet solids then you can thicken them. but I do not think this is the problem I would look at your programming method's.
