Ramping End Mill using BobCad
This seems simple but I'm having a hard time making BobCad do this. I want to cut a 14 degree angle in the Z direction using the back of a 3/4" cutter to generate and angle on a .065" wide straight line surface. I realize that the top of the .065" wide surface will have a conical shape but it doesn't matter. I save an operation by doing this. I've calculated all of the geometry for these cuts in AutoCAD and can do it manually but I should be able to use BobCad to generate the program. Any help would really be appreciated.
Jim
