Tool length offset reduction macro (Sinumeric 840D)
We are using abrasive nylon brush to clean parts on the machine after machining.
We would require a macro of some sort to “shorten” the tool offset by 0.02mm every time program is run.
We tried “L_39 (0,0)” to do this, but it only writes the given value to wear.
Example: L_39 (-0.02,0) would write -0.02 in to “WEAR” section. If run again “WEAR” would stay the same -0.02, not -0.04.
Also, which parameter is used for the minimum tool length?
Example: If our tool is 150mm long, and minimum tool length can be 135mm.
When -0.02 is applied enough times tool length would reach 135mm and then give an alarm or a warning of a tool being too short.
Any help would be appreciated.
Re: Tool length offset reduction macro (Sinumeric 840D)
ello everyone,
I have a task at my new job that I need assistance with. Previously, I worked as a CNC CAM programmer, but I am facing a challenge because I lack experience in macro programming for the Sinumerik 840D. The requirement from our customer is to set a macro where the tool length is updated by about -0.005 or so, then return to the main program, execute it with the new length, and store the actual length of the tool after each execution. Additionally, there should be an option to set a minimum value for the tool. I would appreciate any ideas or suggestions you may have. Thank you.
