Hurco bmc25 spindle drive
A few months back a purchased a hurco bmc25, 1990 ultimax2 control. I had it stored until a few weeks back when I finally wired it up. Initially ad problems with console not working but now have to over that issue to be stuck on another. There is no movement or life whatsoever from any of the axis. The spindle was put on blocks for transportation and that is how it still remains. There seems to be a problem with the spindle control board. There is nothing appearing on the error code display, and no LEDs lighting up. Initially it was blowing fuses due to the fan being jammed but now that is disconnected and fuses are fine but still no life. The input voltage is good and I have had the main board checked for errors and none found. Can anybody shed any light?
