taper on plasma cuts using torchmate machine.
I would like some feedback from anyone . . . This problem is driving me nuts. I have been cutting flanges from 3/8 steel with my torchmate cnc plasma with a powermax 900 plasma machine. i have checked my amperage and voltage settings as well as my speed. everything seems to be about par. The problem is that i am getting a taper on 2 sides of the part, but the other side has almost no taper. I would assume that this would be the nozzle that the plasma comes out of. So i did a test. I cut 2 3 inch by 3 inch squares. one with my old nozzle and one with a brand new nozzle. I got the same result from both, 2 sides have a 1-2 degree taper and 2 sides have an 8-9 degree taper. my table is completely square with my torch also . . . . does anyone have any idea what could be?
Re: taper on plasma cuts using torchmate machine.
Jim,
Previously you stated that the bolt holes have to be a cut a good amount larger than the bolt size. What sizes were cut on the sample that is displayed in the picture with the bolts sliding through your holes. I am cutting with a Powermax 125 on 3/8'' plate creating 1/2'' bolt holes and would like to know what kind of over sizing I should expect to have to implement. Additionally, should I expect to see better cuts while using the higher (125A) amperage settings on the power supply or with the lower (45/65/105A) settings?
Thanks.
