What is the best way to cut thin wall brass tubing?
I have some thin wall .014 brass tubing 11/32 in OD that I need to cut into lengths (1/4 inch and 1-1/2 inch). I'll need about 1000 of these per year.
What is a cost effective way to cut this that would be bur free? I'm using a tubing cutter now -- it doesn't matter that the end is decreased in diameter, but deburring by hand is a pain.
I could use the tubing cutter with the part in the lathe. Would a tumbler or small vibratory finisher solve my bur problem? I was thinking that a small slitting saw would be a lot faster than the tubing cutter -- but would still have the bur problem and might deform the tubing in a way that I couldn't use it.
The parts will be used as spacers. They must still fit into 11/32 (nominal) holes after cutting.
Ken
The problem with deburring tools...
Some of the cut off parts are only 1/4 inch long. That makes them pretty hard to hold while deburring them.
Keep the ideas coming.
Ken
Re: What is the best way to cut thin wall brass tubing?
Hello ,
We are producing metal cutting machine(yag laser cutting machine and fiber laser cutting machine),
we have tube cutting machines,it can cut copper,brass,aluminium,satinless steel etc.
About the pipe,it include round pipe,square pipe and elipse pipes.
If you have any interest in these machines,please contact me.
Contact information: E-mail:[email protected]
Skype:[email protected]
Quote:
Originally Posted by
lerman
Ken
