Originally Posted by
BRobbins
Google wiring for your controller. On the main connector coming out of the supply, there will be an "On" pin (usually the green wire) and several grounds (usually black wire). Take a piece of paper clip or small wire, bend and insert one end in the pin where the green wire is and one where a black wire is. If you are just using this for a computer fan, plug the fan in the appropriate connector. For other DC voltage outputs, see the wiring diagram. I've used these for several projects where I need DC power at different voltage.
