Enco vs. Grizzly square column mill
I got a little aggressive while back with my HF 44991 mill (X2?). Maybe I should only be cutting wax and plastic with this machine? :violin:
As I'm rebuilding and improving the milling head, (I did a little climb milling too and have to tighten up the table). I'm planning a new purchase later down the road for a bigger bench top machine when money and job prospects improve. There's no room in the garage for a Bridgeport. :(
My research has narrowed down to two larger square column milling machines:
An Enco Model #PQ328-6257 with the power down feed and DRO (Rong Fu)
Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
Or the Grizzly G0722 G0722 Milling Machine with Power Feed but no DRO. Grizzly has the DROs but I'll have to install it myself.
The cost would rise to about the same for either machine when I add the DRO to the Grizzly.
I've notice some "slight" differences with these machines. For example, on the Grizzly machine, there's a digital angle readout for the head (how accurate? and if I tram and keep the head at vertical, why do I want or need a head angle readout?).
Now I have to ask the question... :confused: What do you all think?
Anybody in the So. California area own one of these machines?
Thanks in advance.
George
Lancaster, CA
I'd have to go with shipping weight.
This reminds me of barbell sets from the distant past, where a 110 lb set had a shipping weight of 89 pounds. Obviously one of the numbers is wrong, but I'd suggest that shipping weight would be more accurate as the various carriers would likely take acception to grossly mislabeled pallets.
So I'd go with the 572 number. However it would be most interesting to see the machine weighed on a honest scale.
A quick edit here! How many boxes does the machine ship in? I didn't think about that possibility.
Quote:
Originally Posted by
109jb
I'm not sure what to think of the weight of the 0722. If you look at the web page it says the shipping weight is 572 pounds, but the pdf spec sheet says 850 pounds. I would tend to lean more toward it having the higher weight.
