Mill 5 1/2" Aluminum circle 1" thick with center post down to 1/8" Thick
HI,
First off I am trying to get 5 of these made. It is a very basic design the rough mesurments are 5 1/2" outside diameter, with a 3/16" wide wall on the ring, with 10 clearence holes in it. The center is about 5/8" across with a 3/8" hole in the center of it. I also would like 2 rings cut into it for o rings for this needs to be waterProof it will be under water in my pond working with my fountain set up I have with my christmas lights. I attached a drawing that is an old design just so u have an idea what I am refering to with the dimentions, ill try to get an accurate drawing real quick. I also have a design for some air cylinder operated valves i would like cnc'd out of aluminum if the price is right also so there are a few things I need done and multiple of each to be done.
Thanks for any help in advance!
-Will
