2 Attachment(s)
gweike mini cnc router wk2030
Hi everyone,
this is tina from gweike company.lets introduce our hornor model wk2030 cnc router
spec as follows:
WK2030 CNC router
Adopt constant power water-cooled frequency spindle, high speed, low noise and long life.
Three axises are precision ball screw vice transmission, reasonable structure, stable performance, good weight bearing ability.
This machine is mini machine, low price, high performance, especially suitable for home and small enterprises,institutions to do processing .
Users can assemble electric spindle and driving control system according to their own needs.
Specification:
X,Y axis working area:300 x 200mm
Z axis working area: <60mm
Table size: 370mm x 440mm
Max. speed: 0 - 4,000mm/min
Max. Working speed: 0 - 4,000mm/min
Working delicacy: 0.015mm
Reposition accuracy: 0.05mm
Max. Feeding height: 60mm
Command: G code *.u00 *.mmg *.plt *.nc
Software: Type3、 Artcut、 Artcam 、Ncstudio
Max. power consumption:1.2KW
Spindle: 0.8KW variable speed, water cooled motor
Spindle speed: 24,000rpm
Work type: steppernd
Working voltage: AC 220V, 50-60Hz
Manner of receiving data: USB or PCI
Running circumstance temperature: 0 - 45℃
Relative humidity: 30% - 75%
Weight: 57kg
tina from Gweike laser
email: [email protected]
MSN: [email protected]
skype: lysunshine521
