Sabre 1250 tool changer problems
I have a '96 Sabre 1250 that with the awesome help of this forum is finally up and moving around. I'm dealing with the last couple of problems. The main problem now is that the tool changer will not move into position. I go into MDI and type M6T2 and the spindle raises to tool change position, the spindle orientates but the changer will not move into position and a couple alarms pop up. I can hear the solenoid shifting on the valve feeding the changer cylinder. The joints seem very rusty. I soaked down each joint with WD-40 and came in the house for the night. Any ideas on how to verify if the tool changer is rusted solid..easily? Maybe I can remove the bolt thru the eye of the cylinder and try to free it up?
Last question, any ideas how to change the wipers in between the way covers? The all seem to be coming out.
