Just purchased a used WK1325
Ok, guys here's what I know and have learned about components on the one i have.
Note, this one was converted to use Mach3 and uses a controller card from Machmotion.com
My machine components.
1. Controller (Break out Board). Machmotion I06 v3
http://www.machmotion.com/manuals/IO...ard%20V3.0.pdf
2. Drivers: Leadshine MD2278 Microstepping Driver (4 of them in cabinet)
http://leadshine.com/UploadFile/Down/MD2278d.pdf
3. stepper motors: (this is not exact..can't find this exact model). Chinese WANTAI MOTOR model: 86BYGH450-B-40-43.
86BYGH450 series hybrid stepping motor
4. 3Kw spindle 220v 9.5A 24,000 RPM 0523-84506065
5. VFD Taizhou Fuling Electromotor co. (from side panel) input: 3PH 220v
Output: 3Ph 0-220 V
Power: 3.7KW 15.0A
DZB200B003.7L2A
Google Translate
Now, I finally got the machine moving with help from Machmotion but don't have three phase power for the spindle.
If you guys know anything about that VFD or spindle, is there any way for either to work on 240 volt one phase power or would I have to get a whole new setup (spindle + VFD?).
Let me know if you have any other questions or want pictures.
Also, this thing is built like a tank...all steel and 2200 pounds solid.
Rack and pinion on all axis with lubrication system.
The computer that came with it was fried, even the HD, so I had to set it up from scratch.
Need to find out how to set the switches, and motor tuning for those motors and gears on the system.
Any ideas, let me know.
