Wanting to change my Hand Torch to a Machine Torch?...
Hey guys... I'm want to change my current setup on my plasma table from the hand torch to a machine torch.... This way i don't have this big handle sticking out and in the way... not the mention it will/should be more sturdy closer to the Z... I have a Harbor Freight cutter that is working great... however, it does not have any quick change hose mounts, and connections on the outer case... I have to take the case off to make my connections with the new torch... I don't mind cutting and soldiering my connections... Just want to make sure i get a torch i can use... that is not $1,000!!!....
This cutter does NOT have to contact the metal to start cutting... Can I use one of these or do you guys have any better ideas???... Thanks a bunch, Winegar!
SG-55 AG-60 Air Plasma Cutting machine torch 60A 12Feet - eBay (item 200606481590 end time Jun-07-11 23:40:11 PDT)
P-80A PANASONIC Air plasma cutter machine torch 12 FEET - eBay (item 400073560130 end time Jun-07-11 17:44:45 PDT)
