Plasmacam, Torchmate, Samson and so on
Plasmacam, Torchmate, and Samson are some of the systems I have found so far that seem like they are worth a look.
Is there a list of the commonly available (lower priced) plasma CNC systems, what they come with, what they need, as well as an idea on the basic pricing?
I had assumed, and verified that they all (not the huge/expensive commercial units) require a basic computer and plasma cutter, but they are evasive on even the most basic info on prices.
Plasmacam even had one that you could assemble the basic framing to save $$$ on the over all system.
Other than the price on some of the Torchmate systems, and a few numbers rumored on some web sites about what some say they paid, they all want you to call a salesman.
The 2X2 $3000 and 4X4 $4000 for the gantry are not bad as you can adapt another table and fabricate the remaining parts your self.
I $ee that the co$t of the proprietary $oftware is an i$$ue though.
Anyone know about the possibility of using open sourced like FastCut does with the Torchmate?
Any info on the other systems would be appreciated.
High Quality Low Cost CNC Plasma Table Option
Assuming that you didn't want to build your own plasma table, here is an option for a high quality 4x4 table with digital torch height control for under $5K.
http://www.chacich.com/ppllc/4x4bt/bt%20table.jpg
http://www.chacich.com/ppllc/4x4bt/btz.jpg
http://www.chacich.com/ppllc/4x4bt/btend.jpg
http://www.chacich.com/ppllc/4x4bt/bt%202.jpg
This is a high quality table utilizing extruded aluminum rails with hardened v-guides, hardened v-guide wheels, 1/8" sheet metal frame that is powdercoated, 1/2" machined aluminum plates, machined wheel and gear covers with rail wipers/oilers, and a high quality Z axis with floating torch switch for touch and go plasma cutting. The slats are not included since the 1/8" x 3" HRS is more expensive to ship than to purchase locally.
A stainless water pan with integrated slat holders is also an option, but we also suggest using our print and sourcing locally to save money.
The only way to get a table of this quality at this price is to purchase the mechanics and electrical package seperately. The recommended electrical package for use with this machine is the Bladerunner AIO 300-4 with Dragon Cut Digital Torch Height Control from candcnc.com.
In this senario, support from the mechanics would come from Precision Plasma LLC and support for the electronics would come from Candcnc.com. This seperation is what reduces the cost.
Costs:
Precision Plasma LLC bolt together kit $3450
Candcnc.com Bladerunner AIO 300-4 Dragon Cut $1250
Sheetcam and Mach 3 software package from candcnc.com $299
Total $4,999 + shipping
If you were interested in welding up your own frame, you could build a 4x4 table for under $4k and a 4x8 table for under $4.5K
