4-axis mill post and a-axis datum setting
Hi all,
I'm setting up a 4-axis mill post processor, and I'm stuck on the datum setting bit.
I need a line at the start of the program to define my datum, which I do when I program manually, with a line like this:
G10 G90 L2 P1 X661.55 Y-403.58 Z-418.58 A-36.437 (CPL NAME)
which is fine.
However, I can't work out how to get edgecam code wizard to output the A-axis position, so I can only get:
G10 G90 L2 P1 X661.55 Y-403.58 Z-418.58 (CPL NAME)
There are no tokens for the A axis?
In my code constructor for 'set work datums' I've got this:
[DELETE][BLKNUM] G10 G90 L2[WORKREGISTER][XABSORIGIN][YABSORIGIN][ZABSORIGIN] ([CPLNAME])
and I'm assuming I need something like a [AABSORIGIN] token. But there isn't one? How do I define the A axis position?
Hope someone can help!
J
