Hi
I deleted all parameters.
My machine: Leadwell MCV-0 FANUC OM
Please help!!
Printable View
Hi
Please help!!
do you have another one (machine)?
did you check for a list in the back of the machine?
did you call leadwell yet?
You also need the 900 option parameters, the diagnostic/counter/timers and any 9000 macro programs.
Al.
hi,i have a Option Parameters, NC Parameters & Pc Parameters fanuc OM-A MCV-OP leadwell machining centre you need fanuc OM-A.plese send e-mail ([email protected]
Hi we have all parameter of that machine if you required then plz mail me at [email protected]
Another thing if i want to run the machine in dnc mode then,have any bit or M code for the same?
And also we have not manual of that machine can you provide manual?
We have a 1995 Leadwell MCV-OP L2SIE0323, Fanuc OM. We're replacing the memory board and need the parameters for this. Do you have parameters for this model?
[QUOTE=MARCINZUR;790755]Hi
Please help!
Pls send me parameters Leedwell MCV O FANUC OM
[email protected]
You have The OE1 AND OE2 eprom files în hex format?.I change The controller for my MCV with 0MF and i need change The memory on Mainboard.
Pls sens an email [email protected]
Did anyone get the parameters for this? I need them for leadwell mcv 1000bp with fanuc omf control, I have everything working except the tool change, can do most tool change movements in mdi via g and m code but program just stops after g28 z0, maybe a diognostic or timer parameter, in manual mode I get a 1046 then 530 alarm when trying to get to g30 2nd z 0. Thanks
Hartford VMC-1020
SYSTEM:0M
PMC OE1/2 CHIP LOST
I have a Hartford VMC-1020 with Fanuc O-MD system, but the PMC ladder diagram is lost.
Could you please send me an OE1/OE2 file OR Picture? Thank you very much!
Email:
[email protected]
