Laser cutter capabilities question
Hi all,
Im new to laser cutters and I had a few questions. I'm thinking of using a laser to cut through the side of a plastic box. The box will have walls on the order of 1/16" to 1/8" thick. The box wont be very big (1" to 2" wide) and I dont want to cut through the other side of the box as I'm cutting the top. Will the laser be unfocused enough to not cut through the other side by the time it gets there? Also, if it isn't, can I add a piece of metal (or some other material...) inside the box such that the laser does not make it to the other side but instead gets dissipated through the material (deally it would be reusable...). Also, will this method create splatter that makes this inside of my box look awful?
any thoughts? thanks all,
- Will
Tray full of...something...?
Since the boxes have a removable top, and you are putting your hole in one of the sides, this means they will be sitting on the honecomb with one side open, is that right?
Ok, how about a small tray, perhaps fold up some tin plate or something, that slides into the open side and is filled with...something... that will absorb/dissipate the heat. Perhaps kitty-litter, fullers earth, carbon granules, what-have-you...
Whatever you use will get hot, so you could have 2 or more of these trays in use and swap them out as needed.
