post processor for KmotionCNC / help adjusting
hey, andre.
this might be a better place to work on this rather than emailing
i had emailed you last week about my lathe PPR but figured i would warm up on something already functioning ( my milling PPR )
it is a basic 3 axis knee mill with VFD spindle
i have chatbot helping me but we cant get it all worked out
1 i would like to have a G04 with a second per 1000 rpm commanded. can be rounded up to whole seconds
chatbot got me this but it does not add the dwell in the final G code
:SPINDLE = { $SPINDLE:SPIN (M03) eob
(G04 P$SPINDLE/1000) eob ; Dwell 1 second per 1000 RPM
2 trying to have a basic end of cycle details
:FINISH = {
(G00 Z0.5) (M05) (M09) (M30) EOB
3 a basic once over if i am missing or killing something usefull
THANKS
HTML Code:
TITLE:
:T1 = {
KmotionCNC Milling Controller
END:
WORDS:
:TMP = {DDDDDD.dd}
:BLOCK = {"N"DDDD" "}
:XAXIS = {" X"DDDDD.ddd} {" X"DDD.dddd}
:YAXIS = {" Y"DDDDD.ddd} {" Y"DDD.dddd}
:ZAXIS = {" Z"DDDDD.ddd} {" Z"DDD.dddd}
:XARC = {" I"DDDDD.ddd} {" I"DDD.dddd}
:YARC = {" J"DDDDD.ddd} {" J"DDD.dddd}
:KARC = {" K"DDDDD.ddd} {" K"DDD.dddd}
:DELAY = {"G04X"DDDDD.ddd}
:DWELL = {"P"DDDD.ddd}
:PECK = {"Q"DDDDD.ddd} {"Q"DDD.dddd}
:RPLANE = {"R"DDDDD.ddd} {"R"DDD.dddd}
:FEED = {" F"DDDDD.dddI} {" F"DDD.dddd}
:SPIN = {"S"DDDD}
:TOOL = {"T"DD}
:SUBPR = {"P"DDDD}
:REPEAT = {"L"DDDD}
:CRC = {"D"DD}
:TLC = {"H"DD}
:INDEX = {"INDEX"DDD.ddd}
:PROGNO = {"O"DDDDD}
END:
GROUPS:
:G2 = { G17 G18 G19 }
:G1 = { G00 G01 G02 G03 }
:G8 = { G73 G74 G76 G80 G81 G82 G83 G84 G85 G86 G87 G88 G89 }
:G3 = { G90 G91 }
:G4 = { G94 G95 }
:G5 = { G20 G21 }
:G6 = { G40 G41 G42 }
:G7 = { G43 G44 G49 }
:G9 = { G98 G99 }
:G10 = { G54 G55 G56 G57 G58 G59 }
:M1 = { M00 M01 M03 M04 M05 M06 }
:M2 = { M98 M99 }
END:
CYCLES:
DRILL CANNED
DRILLDWELL CANNED
DEEPDRILL EXPAND
NDEEP CANNED
NPECK CANNED
PECKDRILL EXPAND
NPECK CANNED
HELIX VECTOR
ARC QUADRANT
END:
MACROS:
#N = {}
#L = { [RAPID ? (G01) / (G00)] }
#FTYPE = { (G94) }
#X = { ($X:XAXIS) }
#Y = { ($Y:YAXIS) }
#Z = { ($Z:ZAXIS) }
#I = { $XCEN-$OLDX:XARC }
#J = { $YCEN-$OLDY:YARC }
#K = { $KCEN-$OLDK:KARC }
#R = { ($CCLDIST:RPLANE) }
#P = { if ( $CDELAY ne 0 ) then ($CDELAY:DWELL) endif }
#F = { ($FPM:FEED) }
#DWELL = { if ($CDELAY ne 0) then (G82) else (G81) endif }
#RAPID = { SET [RAPID] = 2 }
#FEED = { SET [RAPID] = 1 }
#IPLANE = { if ( [CRETRACT] eq 2 ) then (G99) else (G98) endif }
#CRCX = { [CUTCOM ? (G40) / (G41) / (G42)] }
#CRCNOX = { [CUTCOM ? NULL / ($CRCNO:CRC) / ($CRCNO:CRC) ] }
#CRC = { NULL }
#CRCNO = { NULL }
#Q = { (ABS($CD1):PECK) }
END:
RULES:
:INIT = {
SET $USR1 = 0
SET $USR5 = 2.5
SET $BLOCK = 1
SET $INCR = 1
SET $RAPIDFEED = 10000 ; rapid feedrate
:XPROGNO = { "%" EOB $PROGNO:PROGNO EOB }
:UNITS = {
#N (G20) (G17) (G90) (G40) (G49) (G80) (G94) EOB
IF ([UNITS] EQ 1) THEN
SET $USR2 = 0.0005
SET $PRECISION = 0.001
ELSE
SET $USR2 = 0.00005
SET $PRECISION = 0.0001
ENDIF
:STOP = {
UNSETALL
#N (M00) EOB
:PPRINT = { #N $JOBTEXT EOB }
:RETRACT = { #N (G00) #Z eob }
:INSERT = { #N $JOBTEXT EOB }
:GOTO = {
SET $USR3 = 0
IF ((ABS($DELTAX) GE $USR2) OR (ABS($DELTAY) GE $USR2)) THEN
SET $USR3 = 1
ENDIF
IF (($USR3 EQ 1) OR (ABS($DELTAZ) GE $USR2)) THEN
#L #CRC
$X:XAXIS $Y:YAXIS
ENDIF
IF (ABS($DELTAZ) GE $USR2) THEN
#Z
ENDIF
#CRCNO #F EOB
ENDIF
:GOCLW = { (G02) #CRC #X #Y #Z #I #J #CRCNO #F eob }
:GOACLW = { (G03) #CRC #X #Y #Z #I #J #CRCNO #F eob }
:DELAY = { $DELAY:DELAY eob }
:FINISH = { (_M05) (_M09) EOB
(_M30) EOB }
:CLEARP = {
if ($CLEARP lt $CLDIST) then
ERRMSG "Clear plane is below Wsurf - DANGER"
endif
END:
Re: post processor for KmotionCNC / help adjusting
Hello,
My advice would be to abandon chatgpt as this might lead you down a rabbit hole with no obvious advantage.
If you need any existing post modified you can always contact us, something that might take us 30mins might take you days to resolve.
Thats not to say the chatgpt route is wrong, just a bit like reinventing the wheel as we have soo many existing posts.
One thing to bear in mind when doing any work on our posts is that the syntax is 100% important, 1 odd character or false logic statement can result in no output whatsoever.
ATb
Andre
thanks for the reply.
chatbot has been excellent for me in many ways
the biggest feature is it is always there with an immediate answer
i have used it for months now building fuel injection C codes, paddle shift 6 speed automatic transmission controllers and many other projects for Arduino. ill give you one guess as to what they say on the Arduino forum about chatbot......
i 100% understand chatbot maybe be wrong but like i said it tells me something right away and i learn together how to use it better and learn the material from at least one angle
anyways....
so should i ask questions here or in email form for some help?
still looking to get some input on this idea i would love to have in the PPR
i would like to print a G04 with a second per 1000 rpm commanded. can be rounded up to whole seconds
is there a complete list?
HTML Code:
The postprocessor shown below illustrates most of the programming instructions described in this section of the manual.
TITLE:
:T1 = { MOOG Hydrapath, Copyright : © 1997 Dolphin CadCam Ltd.. }
END:
WORDS:
:N = {"N"DDDDZ}
:X = {"X"DDDD.ddd} {"X"DDD.dddd}
:Y = {"Y"DDDD.ddd} {"Y"DDD.dddd}
:Z = {"Z"DDDD.ddd} {"Z"DDD.dddd}
:R = {"R"DDDD.ddd} {"R"DDD.dddd}
:W = {"W"DD.dd} {"W"D.ddd}
:I = {"I"DDDD.ddd} {"I"DDD.dddd}
:J = {"J"DDDD.ddd} {"J"DDD.dddd}
:F = {"F"DDDD} {"F"DDD.d}
:S = {"S"DDDD}
:T = {"T"DD}
:P = {"P"DD}
:E = {"E"DD}
:D = {"D"DD.d}
END:
MACROS:
#N = { $BLOCK:N }
#X = { ($X:X) }
#Y = { ($Y:Y) }
#Z = { ($Z:Z) }
#R = { ($CCLDIST:R) }
#W = { ($CD1:W) }
#I = { $XCEN:I }
#J = { $YCEN:J }
#F = { if(($FPM lt $USR1)OR($FPM gt $USR2))then
ERRMSG "Feedrate out of range"
Endif
[RAPID ? ($FPM:F) / NULL] }
#S = { if( [SPIN] gt 1 ) then
if( ( abs($SPINDLE) lt 50 ) OR ( abs($SPINDLE) gt 4500 ) ) then
ERRMSG "Spindle speed out of range"
endif
$SPINDLE:S
endif }
#P = { $PROGNO:P }
#D = { $DELAY:D }
#RAP={ [RAPID ? (G01) / (G00)] }
#CRC={ [CUTCOM ? (G40) / (G41) / (G42)] }
#T = { $TOOLNO:T }
#RP= { [CRETRACT ? (M81) / (M82)] }
END:
AXES:
XSCALE 1
YSCALE 1
ZSCALE 1
END:
GROUPS:
:G1 = { G90 G91 }
:G2 = { G00 G01 }
:G3 = { G40 G41 G42 }
:G4 = { G70 G71 }
:G5 = { G80 G81 G82 G83 G84 G85 }
:M1 = { M03 M04 M05 }
:M2 = { M07 M08 M09 }
END:
CYCLES:
DRILL CANNED
DEEPDRILL CANNED
PECKDRILL CANNED
TAP CANNED
BORE CANNED
HELIX VECTOR
END:
RULES:
:INIT = { ; machine startup condition
set [LIMITS] = 1 ; enable axis limit checking
set $MAXBLOCKS = 1000 ; split output files after 1000 blocks
(G00) (G17) (G40) (G80) (G90)(M09) (M05) }
:START = { "%" eob set $BLOCK = 5 set $INCR = 5 }
:PROGNO = { #N #P eob }
:UNITS = { if([UNITS] eq 1) then
set $USR1 = 8 ; min metric feedrate
set $USR2 = 8750 ; max metric feedrate
else
set $USR1 = 0.3 ; min inch feedrate
set $USR2 = 350 ; max inch feedrate
endif
#N [UNITS ? (G71) / (G70)] eob
#N (G17) eob #N (G90) eob }
:TLOAD = { #N "G99" $XTLOAD:X $YTLOAD:Y $ZTLOAD:Z eob }
:ORIGIN = { #N "G92" $TABLOFF:E $ORIGINX:X $ORIGINY:Y $ORIGINZ:Z eob }
:SELCTL = { #N #T "M06" eob }
:INSERT = { #N "(" $JOBTEXT ")" eob }
:SPINDLE= { #N #S [SPIN ? (M05) / (M03) / (M04) ] eob }
:COOLANT= { #N [COOLANT ? (M09) / (M08) ] eob }
:GOTO = { #N #RAP #CRC #X #Y #Z #F eob }
:GOCLW = { #N "G02" #X #Y #I #J #F eob unset (G2) }
:GOACLW = { #N "G03" #X #Y #I #J #F eob unset (G2) }
:GOHOME = { #N (G00) $ZSAFPOS:Z eob #N $XSAFPOS:X $YSAFPOS:Y eob }
:RETRACT= { #N (G00) #Z eob }
:STOP = { #N "M00" eob }
:OPSTOP = { #N "M01" eob }
:DRILL = { #N [CDELAY ? (G81) / (G82)] #X #Y #R #Z #F #RP eob }
:NDEEP = { #N (G83) #X #Y #R #W #Z #F #RP eob }
:BORE = { #N (G85) #X #Y #R #Z #F #RP eob }
:TAP = { #N (G84) #X #Y #R #Z #F #RP eob }
:NPECK = :NDEEP
:CYCLEOFF={ #N (G80) eob unset (G2) unset :R unset :W unset (M3)}
:FINISH = { #N "M30" eob "%" eob
if( $XMAX > 1250 || $XMIN < 0 || $YMAX > 450 || $YMIN < 0 then
Errmsg "Axis limits have been exceeded" eob
endif }
:ENDSEC = { #N (G00) $ZSAFPOS:Z eob #N $XSAFPOS:X $YSAFPOS:Y eob
#N (M09) eob
#N "M30" eob "%" eob }
:NEWSEC = { "%" eob unsetall
#N #P eob
#N (G17) eob
#N (G90) eob
#N #T "M06" eob
#N (G00) #X #Y eob
#N (G00) [UNITS ? ($Z+3):ZAXIS : ($Z+0.1):ZAXIS) eob
#N (G01) #Z #F eob
END:
