Re: Issues with KmotionCNC
I played around with the system today some more. I reverted back to 4.32 and am having the same issues with the gcode hanging on the M5 user programs. It seems to be a hardware issue as this is occurring more and more frequently. It eventually got to the point where the spindle wouldn't even turn on just after initializing the system. An M3 or M4 command would have no effect. Looking at the digital I/Os in Kmotion I can see that the I/Os associated with turning the spindle on get activated but the LEDs on the Konnect are not reflecting the state in Kmotion. So it's either the kflop or the konnect board. At this point I'm leaning more towards it being the kflop as the system would hang on S commands in the gcode and that has nothing to do with the Konnects. I would try to swap the two Konnect boards with each other to see if the problem changes but that would take a few hours to rewire everything and a good chance of mixing some of the wires up as none of them are labeled. Let me know what you think.
-Tom
Hi Tom,
All very strange. Please post all your programs and how they are configured so we can take a look.
One thought I had was that if you are printing Console messages and they are never read then maybe that could eventually cause a hang (although it shouldn't). That the only think I can think of that running an instance of KMotion.exe might do to free things up. When not debugging you might remove all prints.
Maybe there is some conflict in the Virtual I/O Bit settings? Which Digital I/O's are you using and looking at?
Do you realize the Konnect Terminals are pluggable, it shouldn't be too hard to swap.
With regard to ToolChanger M6 Halts: There have been some changes in that area. Previously a Halt that occurred during C Program MCode Actions like M6 would not be immediately recognized until further down in the GCode after some Motion. We felt this was a bug, but your scheme might have been using that to an advantage. It may take some work but I think the new scheme should be better. A Halt during a Tool Change should now stop any axis motion and Halt GCode on the M6 line. When continuing the Gcode the M6 will be repeated. In this case you will likely need to treat it like a special case and fix things up and resume where the Halt occurred.
Regards
Regards
2 Attachment(s)
Hi Tom,
I'm glad you brought up the removable terminals. I forgot they slid onto header pins. Made swapping the two Konnects really easy. After swapping the two Konnects the machine ran fine for the next two days without a hitch however the problem returned on the third day so by this point the Kflop that I order from you had arrived so I was able to swap those out. I noticed that the board I was using before was Rev 1.2 and the new one I received was Rev 1.3. The interesting thing was that the issue I was having with homing the axes and having that deceleration issue went away and now the homing program works as expected. I thought that maybe my kflop was bad and thought that that would fix the Konnect issue I was having.
Today I was running the machine and a similar issue occured where the Konnects became unresponsive. This time on the console an error message was displayed: "COMM ERROR AUX1 A4 (signature not A5)"
I looked around on the web and found https://groups.yahoo.com/neo/groups/.../messages/8999 and I noticed that the length of the ribbon cable was mentioned. I also noticed that Rev 1.3 had a filter cap to reduce noise? Could the length of my cable be the issue here and am being a victim of electrical noise? Will shielding the cable solve the issue or is crosstalk between neighboring lines on the ribbon cable the culprit? I will post a couple of pictures so you can get an idea of the setup and length of the cable.
http://www.cnczone.com/forums/attach...d=284504&stc=1
http://www.cnczone.com/forums/attach...d=284506&stc=1
Hi Thomas,
I would think that a bad KFLOP would be unlikely as it would be hard to imagine how KFLOP could be damaged in a way to still be functional but just more noise sensitive. I suppose it is possible.
The only difference in KFLOP Rev 1.3 and Rev 1.2 is that a filter capacitor on the KFLOP Reset line has been added to reduce the chance of noise coming in the connectors and resetting KFLOP.
The Konnect cables are a bit longer than I would like but that shouldn't be a problem.
Regarding COMM ERROR AUX1 A4(signature not A5). This would indicate a noise problem. Each 180us period the 5 bytes (32 inputs + signature) is read from Konnect and the signature should always be a hex A5 (10100101) pattern. The error indicates a A4 (10100100) pattern was read with an error in bit 0. If a signature error occurs the communication is halted and the Konnects must be re-initialized.
Shielding the ribbon cable may help although I'm not sure where to get shielded ribbon cable. Moving the ribbon cable away from those other cables may help.
You might try adding something like a 16 gauge GND wire between the GND Lugs on KFLOP and each Konnect.
Regards
2 Attachment(s)
Hi Tom,
Thanks for the input. I don't know where to get shielded ribbon cable either but I happen to have some braided copper cable shielding from a cable I took apart when removing the old controller from the machine. I managed to get the cable inside and soldered a wire to the end of it so I can ground the shielding. Hopefully this will do the trick. Only time will tell.
Attachment 284522
Attachment 284524
Tom
We are with high honored manufacture of shaft couplings and vacuum pump blowers used in CNC router.If you need them,I would like to quote you for your reference.Looking forward to your respond everybody.
Skype:z1990338416 Email:[email protected] Attn:kate Mob:86-15069159203
Hi Tom,
Nice. Where did you connect the shield? I would have made as short as possible connection to the KFLOP DC GND Lug.
Regards
The wire to the shield is connected to the ground connections on the power terminals to the left of the board. Thank you for the suggestion. I will try to rig something up and connect the wire to the Kflop GND lug.
Tom
1 Attachment(s)
Tom,
I also had many noise issues on my machine and tried to put additional filter caps on the J4 and J6 connector that goes to the ribbon cables to no avail. It got slightly better but still would pick up noise and hang up my system.
The answer was to add a ferrite core and have the ribbon loop through the core. These cores act as a resistor to EMI noise that can interfere with the KFLOP. See the photo below, as soon as I did this my machine was solid as a rock. I found these on ebay for pretty cheap and they work miracles.
Russ
Attachment 287434
