? about ball-end, corner radius endmills
My first efforts at machining 3D contours in 6061 aluminum are encouraging, but it's clear I have a long way to go. Using an 1/8" ball mill with a very small stepover, I'm getting decent results, but the surface is striated in the direction of the tool travel. I'm assuming this is because the axial point on the tip of the ball has essentially zero rotational velocity.
Would I get better results using a square-end mill with radiused corners, or is there something obvious I'm overlooking?
Thanks in advance for any guidance.
