Re: 770 First impressions
Tormach used to offer at least 1/4" set-screw holders. I have a few but they are pre-TTS so maybe that's part of it.
the keyboard space bar should act as feed hold. Handy to hover a hand over that when watching the machine do a first run program.
The other PP things you should report to Tormach and see what they say-- it sounds bizzare to me.
Maybe there is a belt position switch in PP that tells the control that the belt is in the upper position. I will look in my manual and see about that.
Some thoughts.
1. I don't have a 770, but that still sounds like way too much noise. I can run my 1100 wide open- roughly 5800 rpm on the tach- and barely hear it in the room immediately above the shop. Right next, a bit noisy, but no need for ear protection unless cutting steel. Talk to Tormach some more.
3. Speed readout. This just sounds wrong. When I swap my belt (Mach3 controller) I also have a soft switch to change in Mach. If I don't change it, Mach won't let me go faster than the low speed limit.
4. Tool holders. Search the forum and you'll find some discussion. As I understand it, the issue is runout. A few thou on a 3/8 or 1/4 cutter with a 3/8 shank is no big deal; 10 thou is 4% on a .250 cutter. On a 1/8 cutter, it's twice that. Bad finish and broken cutters soon follow.
Quote:
Originally Posted by
GLCarlson
A decent set-screw holder should have no more than a few tenths of runout. NO holder should have "a few thou" of runout! Even the cheap Chinese knock-offs are better than that.
Ray L.
GLCarlson
Some thoughts.
I have had a 770 for about two years and that seems *FAR* too loud. As I believe that I wrote previously I can easily hear the cooling fan at the top of the control cabinet and the steppers when I have the spindle running but not cutting. If you can't TALK TO TORMACH!
Have you considered the ER16 rather than ER20 holders? I frequently use 1/8-inch shank bits but with 1/16-inch cutting areas and haven't had significant problems with clearance for most jobs. Perhaps posting some pictures of your setups would elicit suggestions for workarounds.
They do still have set screw holders in 1/4 and 5/16. In metric down to 6mm.
I always try to buy my smaller mills with 1/4" shanks when they are available.
J S Machine
3. Spindle speed readout. This is l fine up to 3250, but when the belt is swapped to the upper position to run the higher RPMs, the screen still reads 0-3250. I have no indication of what speed I'm actually running. On top of that, the Override on the path pilot screen does not start affecting the RPM until it is slid down to around 25% (If I remember right). So in other words, the effective range of the override is like 0-25%. I decreased the spindle speed yesterday trying to find a sweet spot for a program, and I have no idea what it was at, other than it sounded a little slower than max speed.
You have to set the spindle range. There is a button in the Manual Control Group that you have to click to select the appropriate range. See Spindle Controls in the manual. If that doesn't work, you should file a bug report with Tormach.
bob
The noise definitely doesn't sound right and could be an indicator of a problem. I would keep talking to Tormach. They are ABSOLUTELY AMAZING at trouble shooting. Like you've experienced, you had a somewhat minor sounding problem and they sent you a free replacement motor. Can you imagine a car dealer replacing a major component purely because you told them "this doesn't sound right"? I promise you, if you pursue this issue with Tormach, they will send you parts/ troubleshoot until the problem is 100% sorted out- they really stand by their products.
