I use the speed override function quite often. My projects are all unique and sometimes my choice of speed is not optimal in CAM.
No problem, I just tweak the speed with the override function from 100% up or down as required for my machine while cutting.
Unfortunately I forget sometimes to reset this to 100% when finished and the machine may start with 200% speed the next job leaving me to scramble to reduce that before the bit breaks.
I think it would be better to reset this internal variable to 100% when a new g-code is loaded. The likelihood that the same adjustment is needed for a different job is very small.
So...I guess this is a feature request for a new version...
