1 Attachment(s)
Fanuc AI 200 buton SYSTEM does not work properly
Hi guys and experts
After loosing references ( X,Y,Z - alarm #300 axis need REF ) I tried to fix
this problem by a help of some information that I got from a Fanuc technician
( step by step = MDI --> buton OFFET SETTING --> set write enable to 1 --> buton SYSTEM -->
dialog window PARAM --> 1815 NO SH --> APC APZ --> set APZ to 0 --> OFF/ON -->
manually axis to zero position --> change APZ to 1 and so on...
Well , I did it for Z axis first , everything was ok, I got rid of 300 alarm of Z ,
Then I started next step for X axis , but instead of PARAM --> 1815 --> NO SH
I started to search 1815 before I jumped into PARAM mode , so I could not get into
1815 parameters (I did not notice I am not in parameter setting menu )and I pushed
buton INPUT in this time
From this I can not get into dialog menu with PARAM DGN etc by pushing butun
SYSTEM . I switched machine ON/OFF a couple of times , tried lots of combination of
pushing lots of butons , without of success.
It seems like buton SYSTEM does not work . It does , but never into PARAM mode .
Is it possible to block buton SYSTEM by inputting some wrong number ?
Anything was lost ? Anything made some mishmash inside a system?
Did I jumped into something that I do not know how to jump out ?
I do not understand ...
What can I do ? I have a backup consist of 6 files ( DAT,DGN,LAD,PHL,PRG,PRM)
Could you give me any advice ? thanks a lot
Re: Fanuc AI 200 buton SYSTEM does not work properly
You set wrong number.
Did you accidentally turn your EDIT KEY off so program and parameter setting are restricted?
I don't think you did anything else wrong. Hard to tell what screen you where at when you started typing again.
tuanpq
very usefull information ...
you spent 0,000001% of your iPhone battery to inform me that I set a wrong number.
quite good advice.....
I think,, facebook is better place to make some jokes...
thank you very much
Quote:
Originally Posted by
vavco
tuanpq
thank you very much
You are wrong again. Machine Tool builder can do everything what they need. But whether they do it on your machine or not, I can answer you. Post some picture.
tuanpq
pictures of what I could post ?
By the way , I am surprised, that it is such easy way
how to "dismantle" system by inputting some wrong
number ... it seems to me ,that only [write enable parameter]
is a main key to some unexpected situation ...
Hello guys
for anybody who will need this information :
So , actually it is Fanuc 21i - MB ( AI 200 was only written at the LCD frame )
As I wrote, the main problem --- wrong inputting number 1815 into some parameters
that are seen in OFFSET SETTING , probably 3208 parameter because by reading
its value it was 0 0 0 0 1 1 1 1
According to the manual , bit #0 marked as SKY can be used for blocking button SYSTEM
So , it happened ( I suppose number 15 from "1815" was interpreted as 1 1 1 1
and rewrote 3208 .
I would like to thank to alex of mexico who gave me a hand to discover it .
So , I changed 3208 to 00000000 and I was able to get into parameters menu
via button SYSTEM and finished what I wanted .
