Servo 150 Power Feed Circuit Board Connectors / Schematic
Hi, the Servo 150 Power Feed on my new acquired Series 1 Bridgeport started acting up and I noticed the power switch/circuit break was loose and kept pushing into the unit. I took it apart and found that the retaining nut was threaded on the inside of the unit (wondering if someone else took this apart and forgot to put it on the outside of the switch). I tried to keep the connectors organized but when I put it back together it keeps tripping the circuit breaker. I also found a ceramic disk capacitor broken of the board that I think goes across pins 2 and 4 of the heavier connectors if you count from the top down. Does anyone have any information on where these connectors belong or a schematic for this unit?
Appreciate any help, Thanks in advance,
-Carey
