CNC Plasma Torch Crashes?
I have a question for everybody running a CNC plasma table. Have you ever had a torch crash? How bad was it and was there any damage beyond just knocking the work piece out of alignment (relative to the work offset)? I ask this because I'm still working on my Z axis design and thought of a way to have a precision holder for the machine torch that also incorporated a break away feature in case the torch ever got hung up on, or crashed into the table or material. Before I went through the trouble and cost of making it I just wanted to see if this was a real world concern or if I was just over thinking things.
Re: CNC Plasma Torch Crashes?
We had a lot of torch crashes when we first bought our table. We developed a collar that clamps onto the torch and three spring feelers sense the top of the metal to prevent the THC from driving the torch down and causing a crash. Also the spring feelers can be used to probe for the top of the material at each new pierce and set the Z height to 0.
plasmapal.com
http://youtu.be/GCcmNgHjUqo
1 Attachment(s)
[QUOTE=PlasmaPal;1586734]We had a lot of torch crashes when we first bought our table. We developed a collar that clamps onto the torch and three spring feelers sense the top of the metal to prevent the THC from driving the torch down and causing a crash. Also the spring feelers can be used to probe for the top of the material at each new pierce and set the Z height to 0.
The type of crash I was asking about was during a traversing move, not a plunging move. My solution was to mount the torch to a plate that used three spherical magnets to hold it to the z axis. I can seem to fine the pictures I took of it but I do have a rendering of the SW model which is attached.
ยต
Attachment 255748
Check out Plasma Torch Protection System | Boss Manufacturing - Home. they have everything you need to get a circuit stop control torch holder or magnetic breakaway for just about any cnc table out there.
This is my mk 2, they really don't take much making, been using this one for a while now, works well, one slight change since then, rather than glue the balls in position I just gave them a quick tack with tig.
DIY Breakaway torch mount - PlasmaSpider.com
