7 Attachment(s)
Laser engraving eight horses
Laser machine has been also used for engraving artwork nowadays,
today we are going to show you how to engraving a famous Chinese painting-eight horses on wood.
Attachment 241924
Needed items:
9mm plywood
non-oil low noise high pressure air compressor
HORSE.CDR
Machine used:
Mars130 with 100w
Suggested settings:
Cutting speed: 5mm/s cutting power: 75%/75%
Engraving speed: 30mm/s engraving power: 45%/45%
*the settings are only for reference, users need to find the best settings by testings
Step 1
Load the design to the software and set the parameters, then click Attachment 241926
to send the file to the laser cutter.
Attachment 241928
Step 2
Put the wood sheet to the machine and adjust the focal distance.
Move the laser head to the correspond place and press “origin” to set the starting point.
Then press Attachment 241930 to start your job.
Attachment 241932
Step 3
Job Done
Attachment 241934
Tips:
1. To make a perfect product, it is strongly suggested to do more tests to find the best power settings.
2. When engraving on wood, it’s suggested to use less air assist to the laser head,
strong air flow will make the engraving too dark.
3. When cutting wood, it’s suggested to use strong air flow to the laser head,
it will improve the cutting quality a lot.
If you’re unfamiliar with how to operate the machine, please watch the below guiding video.
How to use your laser machine
Attachment 241936
Re: Laser engraving eight horses
hi amy
your download does not work
greetings
waltfl
Quote:
Originally Posted by
herby08
hi amy
greetings
waltfl
Dear Waltfl
the "download" is just a icon, it's invalid. smile,
(just show customers how to send the file to machine)
so are you interested in this CDR file?
hi amy
yes I am interested because I like the Chinese art
greetings
waltfl
herby08
hi amy
greetings
waltfl
Hi Waltfl
can you please tell me your e-mail address?
I will send the file to you, ok?
hi amy
thanks for the fast respond , my email address is
[email protected]
thanks again
waltfl
herby08
hi amy
[email protected]
thanks again
waltfl
Dear Waltfl
You are welcome.
the CDR file has been sent to your e-mail,
please check when you are free,
if you have anything unclear,
just ask me freely.
