G130/G131 = no effect whatsoever
G130=Super NURBS on
G131=Super NURBS off
I am in the process of implementing SuperNURBS into our Okuma's post processor, but to my big surprise, I can't make the control react to G130 or G131 commands at all. I've tried G131 with all the F/I/J/D... parameters but nothing ever happens. The only way to activate or deactivate Super-NURBS is through the menu.
What is going on? The control is P200M
Re: G130/G131 = no effect whatsoever
on 131
off 130
"on/off" from code requires "off" from parameters ; thus disable function in parameters before running the code :)
where ? there ? :)
Quote:
Originally Posted by
deadlykitten
on 131
off 130
Oops, of course. Thanks for correcting.
deadlykitten
No effect...
Edit: It says in OSP-P200M manual that SuperNurbs should be switched off on reset or M2/program end, but on this machine it stays on until set off through the menu. The machine is MB-66VBE. Is there some undocumented parameter that controls this behavior?
disable in parameters
power off / on
check status in parameters : should still be disabled
enable from code
during program execution reset the control
check the parameter ... if "on" than is not good
however, to do this, you must 1st enable it from code : did you succed here ?
Does your machine actually have that option ?
It could be Hi2NC .... which uses a different G code
for usage, check out this link (eMastercam)
( F, I, J, D) there are other addresses used.... checkout post #8
1 Attachment(s)
Yep.
Aye.
Yes it is.
Fail. Tried G131, G131 J0 F20000, G131 J1 E0.02,... but it stays off.
I really don't understand what is going on here. Anybody from Okuma?
Quote:
]Does your machine actually have that option ?
Attachment 352842
so only parameter setting will work ... when you asked for G codes i shared you the codes for osp300, but maybe you need other codes
you don't have programer manual or functions manual for 200 ? after a rapid search i can tell that G131 should work 4 u, but i did not find arguments or examples for it
did you tried the codes from the link shared by Superman ?
local Okuma dealer ? :)
I believe HiNC (and its variants) HiCut Pro and SuperNurbs all use G130/131 and it depends on which one your machine has as to which turns on.
you mention you tried the whole long line of code. Is it possible you could post said code for us to review. maybe there's something wrong in there you missed at first glance.
The line of code should look something like this
G131 F10000. J2 E.03 D.01 I3 L5. R.3 K0
