585,967 active members*
4,278 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Post processor error: Coordinate Transformation matrix contains more than rotations
Results 1 to 6 of 6
    Jul 2005
    194
    No matter what post processor I use, I get this error. I've tried cleaning up my drawing and removing duplicates, but the error continues. I can click through it, but I wonder what it means.
    Re: Post processor error: Coordinate Transformation matrix contains more than rotati
    Hello Ksky
    Good day
    Could you tell me your use software for post processor file ? and did you already test the simple file with this post processor ?
    Frank
    AccTek CNC
    Sep 2012
    1195
    You'll need to upload the post processor file for us to help with it(will need to be zipped). We'll also need your machine definition folder for "TormachKS", which is located in "C: > BobCAD-CAM Data > BobCAD-CAM V27 > MachSim". There should be a folder called "TormachKS" there which you should zip and post. Without those, we can't generate the same errors. It works fine and posts fine with my machine and post processor, so there is nothing wrong with the geometry or toolpath. The problem is in the post processor or the machine definition, both of which are used to calculate the code.
    Jul 2005
    194
    I attached my machine definition, I didn't include the post processor file as it happens no matter which post processor I use. I am using the "out of box" BC_3x_Mill.MillPst.
    Attached Files Attached Files
    Dec 2008
    4548
    Edit your machine and put a 1 in the z/z column of the holder transform....
    Jul 2005
    194
    That fixed my problem!
    Thanks!
  1. Replies: 7
    Last Post: 11-14-2014, 07:03 PM
  2. Possible to do Transformation Matrix with Dynomotion CNC?
    By vetsen in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-03-2014, 12:52 PM
  3. Replies: 14
    Last Post: 12-13-2013, 12:56 AM
  4. Post processor transformation
    By korakian in forum Mechanical Calculations/Engineering Design
    Last Post: 12-02-2011, 09:00 AM
  5. Replies: 2
    Last Post: 02-12-2010, 06:31 PM
