Re: Possible New Project- CNC Plasma CUtter
Miller sells a machine style torch for that machine, Torch, ICE-55CM that gives you an extra output connector for using an external trigger switch. However it is very expensive. If you want to us the hand torch I would say just open the case and splice into the two trigger wires. According to the Miller schematic for that machine it is terminals RCI-3 and RCI-4 here is a link to the schematic http://www.millerwelds.com/om/o2228r_mil.pdf.
As for using roller chain to drive the machine axis, It will work. But your edge finish will suffer from the movement not being smooth. The smaller the chain you use the better. The inconsistencies will be noticed the most when cutting arcs. On a 4 x 8 ft table you could buy gear rack for around $300.00 or less. Are you planning on using this for hobby use or business?
sick minds demand sick toys!
