hi
I have a CNC laser ST3060 Liaocheng Xinxing Electronic Co. ltd (50W) with controlled newlydraw.
The results of cutting the plywood not are satisfactory.
The cut in some parts leaves some fibers of the wood, small diaphragms which in many cases make it difficult to retrieve the cut piece.
I tried to lower the cutting speed (usually 30 mm/s, power 100, PWM 1KHz) but the results do not change.
I can not determine a common element that colleges various cases of incorrect cutting.
In a few days, and after various tests, everything starts to work (so 'usually happens;-)
You think that might be a greater presence of glue on the plywood or performance degradation of the tube?
Do you have any suggerimeto, some trick to overcome the problem?
Any advice on how and where to find the best plywood?
Not a problem connected to the rest, but you know if there is any alternative to newlydraw, without having to modify all the electronics of the machine?
thank you in advance
