Lately on a 2 sided flip cut. I have noticed that when doing a flip cut using drive surfaces to control my paths the A180 side does not put the paths to the level that is requested , I usually pick the pathing level to just past half way past center line in rhino , but the pathing falls short of even the model it self. Now I have to leave the drive surface where it is and flip the model do the tool pathing and then change the Gcode to request the flip to A180.
I know it used to work a few weeks back before I installed a new release.
Is there an release to fix this ?
In the attach image you can see the tool pathing only going upwards a few mm or so .
