I've done a lot of searching on this website and others for a users manual for the panasonic dv-700 inverter, and I've come up empty handed. I've got it hooked up and running my bridgeport cnc mill spindle, but unless i start the motor with around 30 hz or less, the drive gives an overcurent fault and shuts down. If I start the spindle at 30hz and ramp it up it to 60hz everything seems fine. No buzzing, no problems what so ever. The inverter came from a surplus store, and as such has absolutely no documentation. Does anyone out there have a manual for this drive. Or at least have used one before and can explain how to set the accell rates, or other variables on it? Any help would be greatly appreciated.
Edit: The inverter is driving a 1980's bridgeport j-head with 1.5 hp spindle motor. Thanks
