I wanted to setup a Mill RPM for Mach 3 similar to what the Lathe chuck belt wheel has and determined the following on the Opto setup used on my 2010 Patriot. Just wanted to pop this info up here for retention.
Adding on a Opto sensor update. The Optical RPM setup on the lathe uses a Fairchild QRB1133 combo IR diode w/ NPN output transistor. This is discontinued but is subbed out w/ an Optek (among many equiv's I'm sure) to an Optec OBP703 series. bought from digikey for $3.50 a piece. Has the 6" lead wires already on as well.
OPB703WZ TT Electronics/Optek Technology | 365-1676-ND | DigiKey
Other RPM solutions also exist: Like this one which I may just go buy. tachoptions
Peace
JJ
