Need to know witch parameter to change so the controll let me operate the chuck in M0 mode.
This may be controlled in the Keep Relays. What make/model of machine is it?
The machine is a Alextech Viper 3000 YMS 2007modell
that function is set by the MTB using the PMC and ladder. you may be able to change a PMC parameter but you will need the MTB manuals for your machine to find it.
if you are operating it manually you can just press reset, operate the chuck then press start to continue.
