Hello All
I am having a once per pocket error it seems to be the same as
http://www.cnczone.com/forums/cincin...t-failure.html
How do you reach and adjust the Proximity Switch and which relay is it
1997 Arrow 500 Acramatic 2100
Hello All
David Rogers
Meadholm Technologies
If you take some tools out of the tool holder disk, swing the disk to the spindle and look inside the disk at the far left, you should see a red light on a prox switch flash on and off as you rotate the disk. This is the once per tool switch. It should be on at each tool pocket and off in between pockets. It may need to be adjusted in a very little bit. If you turn it in to much it will be sheared off, so go slow. The switch may have gone bad and needs to be replaced.
Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
Merkardt55
I moved it in 1/2 a turn and have done at least 30 tool changes with no errors looks great so far.
Thank You
David Rogers
You might want to get a backup switch because your switch may be going bad.
Mike http://cncmachineservices.com
How do I go about sourcing a new switch and cable (its starting to crack)
David Rogers
What is cracking, the cable or the switch??? Look in the electrical prints, it is a common prox switch. I think it is a 24VDC switch. You can measure the depth of the back of the switch ( to get it back to the same position) and remove it to look for the OEM part# or sticker.
When I turned the sensor in 1/2 a turn I noticed the cable is cracking. I can run the machine about 4 hours then errors start coming
David Rogers
I would replace the switch and the cable. It should be a screw on cable. What did you end up doing??
This is the actual part, Fives sells it as part# H-1000734 for $48.00
Products
Mechardt55
I was reading my manual and found notes about tool change relays CR29 CR30 (Schrack# RTE24024 cost around $3.00) the previous owner must of had issues with these two so I replaced them and so far no problem.
David Rogers
Bob
What is Fives phone number?
David
David Rogers
859-534-4600
Thank You
David Rogers
It turns out always to be a bad prox switch, cable or it needs to be adjusted in. Let us know if it continues to be trouble free. I have FIVES number at 1-800-934-0735. Thanks,
By the way, if you under clock the real-time board the sensor adjustment of the once per pocket circuit becomes twice as critical.
The error is back I have the part on order should see it Tuesday
David Rogers
What was the final solution??? Did you replace the switch like I suggested and did you have any more problems?? Let all of us know!!!
Meckardt55
Sorry that I have not gotten back I had another machine down(Acra ADT450 with a Mitsubishi M50 no ladder!) and was working on it .I bought this from Amazon 6-36VDC 4mm Detecting Distance NO Inductive Proximity Switch LJ12A3-4-Z/BY and no errors so far
David Rogers
Is the problem corrected???
Meckardt55
It seems to be solved time will tell
Thanks for your help
David Rogers
