584,861 active members*
4,717 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma OSP-100L TOOL WEAR TABLE A
Results 1 to 5 of 5
    Jun 2014
    3
    How do I flag a tool number in the program so that it will count in Table A of the tool wear page labeled( number of work pieces)? Do I need to replace the T0202 With something else? Any Ideas are welcome The manual is not much help!!
    Aug 2011
    2517
    Re: Okuma OSP-100L TOOL WEAR TABLE A
    its not clear what you want to do?
    do you mean tool life management? so that after X-number of work pieces the tool changes to the next spare tool?
    Apr 2006
    822
    I recall using commands like TG=01 OG=01 instead of T010101 on an old LC20 OSP5000L-G to use tools assigned to Groups rather than actual physical tool numbers.
    i.e. I could assign multiple tools to a specific group that I could set via the tool data pages.
    I could set different ways that each tool could expire, i.e. Cut Time, Tool Wear (established via probe results), or QTY of parts machined.
    TG= Tool Group
    OG= Offset Group
    Maybe this will help?
    Brian.
    Aug 2011
    2517
    yes that is tool life management and would work if he has the TLM option.
    That is only useful on a multi-task machine with ATC
    I think we need to see a screen shot of the screen he's talking about and/or his machine model to know for sure what he wants.
    Apr 2009
    1262
    It can be incremented using VTLCN if I remember right.
    VTLCN[1]=VTLCN[1]+1
    Best regards,
  1. Tool Wear
    By rckdef in forum Haas Mills
    Last Post: 08-09-2014, 01:32 PM
  2. Tool Wear Adjustment
    By nfrees114 in forum Haas Mills
    Last Post: 08-08-2014, 01:04 AM
  3. Replies: 2
    Last Post: 02-11-2014, 01:17 PM
  4. Replies: 7
    Last Post: 01-23-2013, 05:46 PM
  5. tool wear indicater
    By Vern Smith in forum Haas Mills
    Last Post: 03-20-2007, 07:09 PM
