585,754 active members*
4,260 visitors online*
Results 1 to 15 of 15
    Sep 2006
    222
    Okuma Multus U3000
    We are planning to buy new multiaxis lathe.
    We have already Macturn 350 OSP100 & MActurn 350 OSP200 and 2pcs Multus W400.
    Okuma has changed models, so Macturn 350 is no longer available.
    New model is called Multus U3000.
    Multifunction | Multi-tasking | CNC Lathe | MULTUS U3000
    Any experience about this new model ?
    I notice that milling head y-axis moveis no longer "triangle" move, its straight one like in Mori NT.
    What about lower turret chip guard in both sides ...it look like to be flat space where chips will be jammed??
    Any comments about this new machine would be great.
    Competitors are:
    Mazak integrex i-400
    DMG Mori NT4250
    Takisawa TMM250
    Which one would y buy ?
    -GB
    Jan 2009
    47
    Re: Okuma Multus U3000
    You have a bunch of Okuma's why would you change? We have 3 integrex machines with the old wedge type construction that are still great machines but our newest Integrex with the straight out Y axis is even better. We do aerospace and medical work that is true 5 axis the post from your cam system is the mist important factor in your decision.
    5 axis Integrex: 5 axis Integrex - YouTube
    The vid is a medical part. The pic below is an aerospace part
    Sep 2006
    222
    Thanks for reply.
    Nobody has yet bought this new model ?? I would not like to be first one
    Aug 2011
    2517
    In 2011 (or maybe it was 2012) the Macturn 350/OSP300L we bought with 165kg Fanuc robot came in at around $2M installed. The number of people spending that kind of money on new machines in countries that are not China or India is pretty low and the number of people here on CNCZone who have done that is even lower. Since that model is very new the number of people who might buy or have bought that model is even lower.
    See the pattern.... ;-)
    It's highly likely you would be the first one (at least here on CNCZone).
    Sep 2006
    222
    Got that point fordav
    We'll ill let y know what happend. We will put Motoman165kg to front of it so this machine will get rough future in our workshop.
    Machine is not yet sure, but i think Mazak or Okuma.
    Aug 2011
    2517
    I doubt the Okuma design is better than the last so make sure you buy a spare set of slide covers ;-)
    Jun 2011
    124
    Quote Originally Posted by fordav11 View Post
    Amen
    Feb 2009
    6028
    Mazak has certainly been doing it longer, even though I'm not a fan of Mazak quality, they do have the multi type down pretty well.
    Nov 2010
    89
    It is a complet new design on the X-Y and Z Axis.
    Aug 2011
    2517
    ok, but is it better and have they fixed all the problems with the Multus design.... that is the question.
    Nov 2010
    89
    Well that depends on what you believe is problems But the new Machine is quite good, they have made some stupid design stuff but that is mostly for service People where that is a pain in the ass, for operators it is a good Machine, they seam to leak a bit on the top of the door but you Can live with it, also order the automatic door, that 2 piece One sided door is a ***** to open and close all the time if you have sub spindle
    Aug 2011
    2517
    the problems we are/were having were busted slide covers jammed with swarf after just 6 months in production, ATC throwing out tools and coolant leaking out of the end of the machine where the chip conveyor is. not to mention endless alarms about many stupid things. we also have trouble holding limits (on diameter and concentricity) on the Macturn. most problems Okuma dealt with but they returned after some time. now we only use the Macturn for roughing work so we avoided having to re-re-re-fix the tolerance issues and in 6 months the machine will be sent to our R&D factory since it is so unreliable it is no good for production.
    Sep 2009
    93
    just ran a batch of parts on a 15 year old macturn.
    even with the bt40 taper holders swapping between an 80° rougher and 35° finisher, the shaft diameter didn't move more than .0005" from cool morning to hot afternoon.
    machine came standard with a scale on x axis.
    sweet.
    Sep 2006
    222
    Not happy with i-400ST.
    If someone has Macturn 350 or 550 for sale please contact PM.
    Nov 2012
    70
    Have sent you a PM
    The Swede
  1. Okuma Multus
    By Kevgerber in forum Okuma
    Last Post: 09-11-2014, 08:12 PM
  2. Okuma Multus Post
    By tsaladyga in forum Post Processors for MC
    Last Post: 10-01-2011, 03:54 PM
  3. Okuma Multus Touch setter
    By Green Button in forum Okuma
    Last Post: 09-06-2011, 11:35 AM
  4. Feature cam and Okuma Multus
    By garnetram in forum FeatureCAM CAD/CAM
    Last Post: 02-22-2010, 03:16 PM
  5. just ordered an okuma multus
    By cncclimber in forum Okuma
    Last Post: 05-13-2008, 08:02 PM
