Hello, due to a backup battery failure, we had to reload the whole system on a LNC8 Okuma Cadet lathe with the OSP700L controller. We were able to install the 12 disks into the machine's memory but it seems to be missing some functions. It alarms out for instance, because of the lubrication times, in the related lubricating time screen all parameters are just zeroed. If we enter random values there we can get rid off that alarm, but that is just an example. Another issue we noticed is that if we try to move any axis the machine will alarm saying the tool setter arm is down, when it's not. The tool turret will alarm after a tool change request, saying the tool number is not right, and so on. I know these are not actual machine problems, cause it was working fine before the batteries went dead.
We have the A.TOP parameter backup file in disk and in text file, we couldn't install this file from the floppy drive, it just reads files in ISO format, not the A.TOP which we know is there, in the disk. We were able to transfer that file from the PC via RS-232, unfortunately the machine keeps missing the functions mentioned before and can not work.
Questions are: Do we need to have any other disk, besides the 12 we already installed? Exactly how are we supposed to restore the parameter file (A.TOP) contained in the extra floppy?
Thanks in advance.
