Originally Posted by
laserpilot
Hi guys, After a lot of help from guys on here I have managed to get a small gantry style milling machine running for over a year now. I am glad to say it cuts alluminium superbly and operates faultlessly.
I have now decided to build a much bigger machine but MOSTLY for wood routing. The size will be 4'x3' Gantry style.
I am unsure for a machine this size should i use Aluminium or Mild steel for the base The design will be for a bench router so the base will also be the mounting point for the Drive rack as well as the Linear Guide Rail. . The choices are
1/ Aluminium rectangular box section, 6061T6, 5"x 2.5" with a 3/8" wall thickness, $40 / Lin Mtr
2/ Mild steel rectangular box section, 4" x 2" with a 1/4" wall thickness. $32 / Lin Mtr
