While it would be ideal to find a really cheap solution to this age old problem of powering your spindle, it's just not realistic if you need/want a solution that has good performance characteristics and almost zero maintenance (you have to clean the air-filter on occasion).
Those high-RPM spindle motors you see all over e-bay don't perform well below 3,000RPM and most don't recommend operating below 6,000RPM, anyone telling you they operate it at 100RPM is not telling you the truth, do the math, required thermal dissipation at 6Hz (300RPM) for a typical china 2-pole (18,000RPM or 24,000RPM) water-cooled spindle motor is 135W/cm2 requiring 23.15cuL/sec, at 60Hz (3000RPM), 42W/cm2 requiring 2.89cul/sec and most inexpensive pumps are in the range of 5L to 100L per minute so it's obviously not designed to run at such low speeds which is why people burn them up.
Yes, you can add a chiller making the thermal transfer co-efficiency higher (a bigger fan and bigger radiator) reducing the required flow but now your adding expense to make your unsuitable solution work for you so your $500.00 solution just got more expensive without improving it's performance (your spindle and VFD cost $400.00 and you spent $100.00 on a cooling system).
Asynchronous Servo Spindle Motors that are specifically designed for VMC's and milling machines will offer you the best performance for your dollar and despite popular belief, they are available in small/lighter packages.
A typical Asynchronous Spindle Servo Motors in the 1.5KW - 2.2KW power range weigh in at about 50lbs to 60lbs and are quite large in size (140mm x 140mm x 480mm is the smallest I could find), so utilizing these monstrosity is cumbersome and difficult at best and too large for most bench-top or home/hobby machines.
There are options in smaller packages and lighter weights but sourcing isn't easy as these products aren't generally offered in the retail market and usually have MOQ's associated with purchasing.
This is what I've been running for a few weeks now and wish I had done this years ago.
Motor Specs: (real) Asynchronous Servo Spindle Motor
- 1.12KW (1.5HP) Constant Velocity / 1.5KW (2HP) Constant Torque.
- Input: 157VAC-3PH / 220VAC-3PH @6.81A
- RPM: 12,000.
- Duty: S1@8,000RPM, S6@12,000RPM.
- Cooling: External 220VAC Electric Fan.
- Foot-Print: 95mm x 95mm x 240mm
- Shaft DIA: 22mm with 6mm keyway (standard).
- Encoder: Optical A/B/Z - 2500PPR
- Net Weight: 18lbs
- Supports Rigid Taping.
- Supports Orientation
I've been running this with a VFD sample I was trying to produce that didn't fund on KS, it has 4 programmable orient positions and a true servo mode, I've had no issues doing anything with this motor, RPMs from 120 to 12,000 are stable due to closed-loop tracking, in servo mode, positioning is accurate within 3ppr and in orient mode it's also less than 3ppr (5ppr is the default position auto-error correction margin, can be changed in the VFD) of the target position.
I've managed to have a manufacturer produce a single-phase input VFD with PG card and four programmable orient positions in a 2.2KW power range making it ideal for this motor and a sample is expected to arrive in about 38 more days with a price tag of $500.00 plus shipping.
At about $1K for the combo it's the best bang for the buck all things considered and it would be impossible for anyone with intelligence to conclude that a 3.8HP brushed DC motor solution could even come close to offering constant torque over such a broad RPM spectrum that can be achieved from an asynchronous spindle servo motor because low RPM is derived by lowering the voltage thus reducing torque to a point that it's just not effective.
Forget Yaskawa VFD's if your on a budget, even a new Delta VFD-VE (3PH input only as single-phase units were never produced) with PG card that will run on single phase 220V (derated) with sufficient power (5.5KW needed for 1.5KW-2.2KW motor) will run you over $800.00 plus shipping, used is less and sometimes old-stock can be found but sourcing the motor is where you run into difficulties as it's not likely you have a local source for special application motors and it's not something you will see advertised in your local hardware store.
Yes, a couple of people might find something suitable on ebay in the way of a mitsubishi VFD with PG card but it is unlikely more than a couple would find something
Attached is a picture of the motor and of one disassembled for those wanting to see what is being referenced in this post.
I made this post at the request of a friend who follows these types of threads and thought that showing there are real solutions available is needed.
Before you get any brilliant ideas of messaging me here to inquire about the motor and VFD combo, if you do message me here, don't expect a reply any time soon, I don't frequent here often and it may be 3-6 months before I return again and the message will have evaporated before this time, if you can't figure out how to contact me off-site, chances are you don't need to contact me.
