I just took delivery of a nakamura tmc3b with a fanuc 6t
Powered it up today and noticed a couple of things.
I can only view a program in edit mode. When the program runs in memory mode it just shows the command screens or position screen but not the active program text like my other nak with 6t.
Also occasionally the turret will unclamp but the turret will not turn. I then press reset and the program stops and that is when the turret starts spinning and never stops. Sticky relay maybe?
Maybe first issue is a parameter bit change?
